Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Windows 11 - not possible to open/save/save-as |
| Print at Oct 5, 2026, 8:30:49 AM |
| Posted by BaaronHaffax at Aug 26, 2022, 10:41:00 AM |
Re: Windows 11 - not possible to open/save/save-as Correct, when I do not open an existing document, the changed will be saved (manually or by clicking "save" on closing), it is not possible to open or save-as, the window to choose a file/filename does not appear. |
| Posted by Puybaret at Aug 26, 2022, 1:18:38 PM |
Re: Windows 11 - not possible to open/save/save-as I tried to use the command "SweetHome3D.exe -log MyLogFile.log" This command was just a suggestion from starrunner, you should rather use a command like:"C:\Program Files\Sweet Home 3D\SweetHome3D.exe" 2>MyLogFile.log---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by BaaronHaffax at Aug 26, 2022, 2:07:42 PM |
Re: Windows 11 - not possible to open/save/save-as I finally did it! I opened the "sample" file and deleted all walls and interriour. Then I wanted to delete the "background" picture - editting was possible, but no opening of a new one. So I deleted the background file... Tried to "open" a new file - tada! "Open" dialog appeared, and from that time I was able to open, save and safe-as any file! Finally it worked, no clue why, but now it is fine again! By the way, I also tried the line you posted, no difference - no log-file was created. Tzhanks for your support!! |
Current timezone is GMT Oct 5, 2026, 8:30:49 AM |
