Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Dimensions - Appearance |
| Print at Oct 5, 2026, 6:26:29 PM | |
| Posted by decard at Aug 30, 2022, 6:33:45 AM |
Dimensions - Appearance can you change the appearance of the Dimension lines? eg make it dashed or dots? this would help make Dimensions much clearer visually and not confused with other plan solid lines obviously, should be a selection option in Dimension Preferences |
| Posted by Puybaret at Aug 30, 2022, 12:13:27 PM |
Re: Dimensions - Appearance Dimension lines appearance can't be changed. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by decard at Aug 30, 2022, 12:23:41 PM |
Re: Dimensions - Appearance noted. thank you. hopefully i am giving you ideas for enhancements? :-) |
| Posted by Puybaret at Aug 30, 2022, 12:31:18 PM |
Re: Dimensions - Appearance I had the idea to allow a different color for dimension lines, not sure it will also allow the change you hoped. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by decard at Sep 4, 2022, 1:13:49 PM |
Re: Dimensions - Appearance I had the idea to allow a different color for dimension lines, not sure it will also allow the change you hoped. yet you already have this function in (somewhere that i cannot remember where i see) :-) |
| Posted by Puybaret at Sep 4, 2022, 4:58:07 PM |
Re: Dimensions - Appearance You won’t find this idea anywhere since I didn’t program it yet! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Keet at Sep 4, 2022, 6:31:30 PM |
Re: Dimensions - Appearance You probably saw it with the polylines, those you can change. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by decard at Sep 6, 2022, 6:12:29 AM |
Re: Dimensions - Appearance You probably saw it with the polylines, those you can change. that's it!! :-) thanks for reminder. |
Current timezone is GMT Oct 5, 2026, 6:26:29 PM |
