Print at Oct 4, 2026, 1:59:20 PM
Posted by hobbyrv at Sep 17, 2022, 11:23:29 AM
system stops
Sometimes the program stops working, I close via task manager, then usually it works again. But now not anymore, objects only partially load and I can't click on anything. What to do and how?
Posted by hobbyrv at Sep 17, 2022, 12:46:26 PM
Re: system stops
See screenshot, in addition: http://icecream.me/578878ccd058aaac42c3a7108e36c228
Posted by Puybaret at Sep 17, 2022, 3:50:58 PM
Re: system stops
Check in About dialog box if you installed the 32 bit version. If it’s the case, run the installer again and choose 64 bit architecture in the screen which lets you choose the installation folder.
Posted by hobbyrv at Sep 18, 2022, 9:55:55 AM
Re: system stops
Perhaps a stupid question, but what dialog box do you mean?
Posted by hobbyrv at Sep 18, 2022, 2:27:08 PM
Re: system stops
I found it, but it's 64 bit already, zothat isn't the cause.
Posted by hansmex at Sep 18, 2022, 4:16:32 PM
Re: system stops
If you share your file, I can see if I get the same problem.
Posted by hobbyrv at Sep 20, 2022, 7:16:10 AM
Re: system stops
Heb je private message ontvangen? Ik zie het niet terug namelijk in het overzicht. Vraag is o.a.hoe ik de file kan toevoegen, ik zie geen optie voor bijlagen.
Posted by hobbyrv at Sep 20, 2022, 2:01:27 PM
Re: system stops
Ik heb nog even verder gekeken en zie dan dat mijn pc wel 64 bits is, maar Java 32. Kan het daar mee te maken hebben? Kan ik dan zonder problemen Java 64 downloaden?
Posted by hansmex at Sep 20, 2022, 2:21:00 PM
Re: system stops
Dat zijn dingen waar ik weinig verstand van heb, maar het lijkt me logisch dat je op een 64-bits syteem 64-bits software gebrukt...
