Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Carpet - fitting to odd shaped room |
| Print at Oct 5, 2026, 6:26:26 PM | |
| Posted by Weevoir at Sep 18, 2022, 4:05:28 PM |
Carpet - fitting to odd shaped room I have an odd shaped room to fit a carpet in I have downloaded and recoloured a suitable carpet - but am unable to do anything with it to change its shape from rectangular My room has a diagonal across one corner (fireplace) - I have tried dragging the shape but it won't do anything but staying with 90 degree corners Also I have coloured it and it appears in the plan as Coloured - but not in 3d - what am I doing wrong ? |
| Posted by Keet at Sep 18, 2022, 5:20:11 PM |
Re: Carpet - fitting to odd shaped room You can only change the displayed dimensions for an object, i.e. width, depth, and height. So you can stretch but not change it's basic shape. For what you want you are better of drawing the shape you want as a room, set a texture/color, export it and import it as your carpet. After import you can still change the texture/color if you want but no longer change the basic shape you created. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Weevoir at Sep 19, 2022, 10:03:07 AM |
Re: Carpet - fitting to odd shaped room So - I can only fit a carpet in a rectangular room ? Shame |
| Posted by hansmex at Sep 19, 2022, 10:11:10 AM |
Re: Carpet - fitting to odd shaped room To draw a room in SH3D you (generally) need to do two things: 1 - draw the walls 2 - insert the room to get floor and ceiling Read the manual and in-program Help to see how this works. If you want to add "carpeting" to the entire room, you can give the floor of the room a texture. If you want to add a rug (or carpet) you can use one of the suggested models, or draw your own model. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 5, 2026, 6:26:26 PM |
