Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: problem with use on linux |
| Print at Oct 4, 2026, 1:58:23 PM | |
| Posted by frpatte at Sep 20, 2022, 9:48:10 PM |
problem with use on linux Bonjour, In fact I have 2 problems: 1- I installed sometimes ago SweetHome3D-6.6 and I could not use it because: "I had to update the drivers of my graphic card"... I never find what I had to update because everything was update... I install SweetHome3D-7.0.2 today and... the problem is still there... I use fedora in its last version with all drivers in their last version: graphic card is nvidia GeForce GTX 1050 Ti (which not a down market product) and all the drivers are in the last version for this card... 2- I try to install new furniture, so I go to: http://www.sweethome3d.com/freeModels.jsp and chose a model to import and use the "furniture import" tool as said in the manual; everything goes well: the answer is: the file.zip has been added to the catalogue. But nothing has been added, I cannot find what I added. Same thing if I unzip the stuff and try to add one of the unzipped file. Same thing if I try to add a .obj file or or a .sh3f file. What can I do? F.P. |
| Posted by anonnymouz at Sep 22, 2022, 1:53:30 PM |
Re: problem with use on linux Try do download a library from source forge: http://www.sweethome3d.com/importModels.jsp#ModelsLibraries Uncompress the zip file and, instead of using "Import forniture..." menu, go to "Forniture >> Import forniture library" and open the .sh3f uncompressed file. |
| Posted by digitaltrails at Sep 25, 2022, 3:48:32 AM |
Re: problem with use on linux Bonjour, ... I use fedora in its last version with all drivers in their last version: graphic card is nvidia GeForce GTX 1050 Ti (which not a down market product) and all the drivers are in the last version for this card... ... What can I do? F.P. I'm using SweetHome3D with an Nvidia 1650-Super on OpenSUSE. I'm using Nvidia's proprietary driver. When ever using Nvidia cards with Nidia's driver, I have had to edit the SweetHome3D startup script and add the option -Dcom.eteks.sweethome3d.j3d.useOffScreen3DView=true. Have you tried that? The edited line would look something like: exec "$PROGRAM_DIR"/runtime/bin/java -Xmx6g -Dcom.eteks.sweethome3d.j3d.useOffScreen3DView=true -classpath "$PROGRAM_DIR"/lib/SweetHome3D.jar:... |
| Posted by frpatte at Sep 25, 2022, 9:34:16 AM |
Re: problem with use on linux I just tried the code you sent and it kills the terminal! |
| Posted by digitaltrails at Sep 25, 2022, 10:32:55 AM |
Re: problem with use on linux I just tried the code you sent and it kills the terminal! It reads like you just entered the line in a terminal - which is not what I suggested. To be clear about what should be done:
| Posted by frpatte at Sep 25, 2022, 10:41:59 PM |
Re: problem with use on linux Thank you.... This works! F.P. |
| Posted by digitaltrails at Sep 26, 2022, 5:15:18 AM |
Re: problem with use on linux Thank you.... This works! F.P. Good news. This should be a FAQ. The FAQ should also state that this is almost certainly true if you are using an Nvidia GPU with Nvidia's proprietary driver (which could be tested by seeing if 'lsmod | grep nvidia_drm' returns a match)." |
| Posted by frpatte at Sep 26, 2022, 10:58:45 AM |
Re: problem with use on linux In fact, I don't use the proprietary driver but the one you can find on the rpm-fusion repo. Regards. F.P. |
| Posted by digitaltrails at Sep 26, 2022, 9:16:32 PM |
Re: problem with use on linux In fact, I don't use the proprietary driver but the one you can find on the rpm-fusion repo. Regards. F.P. On a brief look, the rpm-fusion repo appears to exist to ship non-free software that Redhat declines to ship due to licencing/copyright issues. The repo offers the non-free Nvidia proprietary driver. So you are most likely using Nvidia's proprietary driver without knowing it. This driver is the one that comes with the nvidia-settings and nvidia-smi applications. |
Current timezone is GMT Oct 4, 2026, 1:58:23 PM |
