Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Can you explain the furniture 'Movable' option |
| Print at Oct 3, 2026, 3:40:54 AM | |
| Posted by shoulders at Oct 21, 2022, 9:33:47 AM |
Can you explain the furniture 'Movable' option Hi In furniture editor, models have the option 'Movable' and I cannot find out what this means. In the API I found the following page http://www.sweethome3d.com/javadoc/com/eteks/...at-float-boolean-boolean- movable - if true, the new piece is movableBut his does not help without context. thanks |
| Posted by Puybaret at Oct 21, 2022, 10:04:57 AM |
Re: Can you explain the furniture 'Movable' option When the base plan is locked, only movable furniture can be selected and moved in the plan. It's typically used for windows and sanitary. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by shoulders at Oct 21, 2022, 6:26:04 PM |
Re: Can you explain the furniture 'Movable' option Many thanks. P.S. I don't think email notification from your site is working. |
Current timezone is GMT Oct 3, 2026, 3:40:54 AM |
