Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: SweetHome3DJS model not saved in sh3d file |
| Print at Sep 28, 2026, 2:37:19 AM | |
| Posted by bernard_s at Oct 29, 2022, 11:43:08 AM |
SweetHome3DJS model not saved in sh3d file Hi I have a problem where the online version does not store models chosen correctly. If I add a desk from the furniture list to the plan, when I download and examine the unzipped sh3d file, the object file is not present. In addition, in Home.xml, the model attribute points to a url which contains the domain name of the server. eg model=jar:http://18.135.111.130:8080/SweetHome3DJS-7.0....s/desk.zip!/desk.obj' No ContentDigests file with SHA-1 key exists either. The problem is this sh3d file is no longer portable. If I try to open it in the desktop version, the desk cannot be referenced and shows as a red box instead. I compiled (successfully) and deployed v7.0.2 on tomcat. I note that if I use the hosted version on https://www.sweethome3d.com/SweetHome3DOnlineManager.jsp I can add the desk, download the sh3d file and see the link is correct and a ContentDigests file with SHA-1 key correctly created. Using Debian 10, and OpenJDK 11. I believe the same applies to 6.6.4 which I was using and where I found this issue. Any help gratefull received. |
| Posted by Puybaret at Oct 31, 2022, 3:36:14 PM |
Re: SweetHome3DJS model not saved in sh3d file I have a problem where the online version does not store models chosen correctly. The Online version stores models and textures differently and the sh3d file that it handles can be opened with the desktop version if your server 18.135.111.130:8080 can be reached.If you want to include in the sh3d file all the models it uses, just override createHomeOutputStream in a subclass of HomeServerRecorder to return a DefaultHomeOutputStream instance which will write also models and textures, for example: new DefaultHomeOutputStream(new BufferedOutputStream(new FileOutputStream(homeFile)),But keep in mind that this will create more traffic between the server and JS client, and the sh3d files stored on the server will take much more room. I would rather recommend to create an export function that will read a sh3d file stored on the server and return the content of a full sh3d file. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by bernard_s at Nov 1, 2022, 9:11:41 PM |
Re: SweetHome3DJS model not saved in sh3d file Thanks for the info. That makes sense, as does the extra server load issues it would create. |
Current timezone is GMT Sep 28, 2026, 2:37:19 AM |
