Print at Oct 6, 2026, 5:06:18 PM
Posted by petrk at Oct 30, 2022, 10:37:37 AM
How to export polylines or walls
I am trying to export custom compass world sections object which indicates parts of my house to specific world side (using within feng-shui) so I am considering 2 approaches
1. create this rosary with polylines, but I couldn't find any solution how to export them and import into another project, they could be merged into single polyline as well.
2. create this rosary with walls with small height, which has benefit to see it also in the 3d view not only in the Plan, but when I export walls as object and import it, in the plan I cannot see exactly this lines from the top view in the Plan which is important to place it to right place, because it is specific by the lines inside..
Possible solution
also considering that if there would be a solution to lock walls together and have option to export this group of walls and re-import them to another project it could be enough.
for imagination there is an image how it looks like in practice
NOTE:
if there is somebody who is experienced with creating custom 3d objects, and would be able to create this Rosary as a special 3d tool, I am able to pay for it, in this case, let me know at [email protected]
Posted by Daniels118 at Oct 30, 2022, 9:03:43 PM
Re: How to export polylines or walls
Have you tried to copy the walls and paste them in the other project? I mean copy with CTRL+C and paste with CTRL+V, not export/import.
You can do this with walls as well with polylines, furniture and any other object SH3D can handle.
Posted by Keet at Oct 31, 2022, 3:06:30 PM
What do you mean by a "special 3d tool"? An object representing the map you showed seems rather simple to do but I suspect you have something else in mind?
