Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Staircase shows sky |
| Print at Oct 7, 2026, 8:30:23 PM | |
| Posted by LMA1324 at Nov 15, 2022, 10:59:40 AM |
Staircase shows sky Hello! How can I make sure that the staircase does not show the sky but the level above. The "show ceiling" box is checked on both levels. You can see what I mean here https://ibb.co/vZ2DPTk The problem lies with the staircase. I did not misfit the room and walls. Thank you! |
| Posted by Puybaret at Nov 15, 2022, 6:38:07 PM |
Re: Staircase shows sky Select the 3D view > Display all levels menu item. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 7, 2026, 8:30:23 PM |
