Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How do I close my walls? |
| Print at Oct 4, 2026, 10:08:22 PM | |
| Posted by function10 at Nov 19, 2022, 12:23:56 AM |
How do I close my walls?When I draw 4 walls, how can I get the ending of wall 4 to neatly fit with the starting point of wall 1? Looking at the image below, my problem is the left hand corner. The right hand corner is not boxy. The right hand side corner is an automatic join when I click several times to place multiple walls. ![]() |
| Posted by Puybaret at Nov 19, 2022, 3:06:49 PM |
Re: How do I close my walls? Double click on the start point (the starting wall will be colored when you approach it), or afterwards, use the Plan > Join walls menu item (see this article). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Keet at Nov 19, 2022, 3:07:28 PM |
Re: How do I close my walls? Select the two walls you want to connect, right click, and choose 'Join walls' from the context menu. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by function10 at Nov 20, 2022, 1:45:29 AM |
Re: How do I close my walls? Thank you Puybaret & Keet. I did not see that info here: https://sweethome3d.com/userGuide.jsp#drawingWalls |
Current timezone is GMT Oct 4, 2026, 10:08:22 PM |
