Print at Sep 29, 2026, 5:15:51 PM
Posted by michielper at Nov 29, 2022, 5:07:46 PM
making walls invissible
Is it possible to make a wall invissible?
I am trying to make an attic wich has four tilted roof sides. I can create four rooms with a tilted roof but this requires a lot of inner walls. What I would like is to keep the walls controlling the roof tilt but without the walls being visible....
Is this possible or is another solution more logical?
Posted by Puybaret at Nov 29, 2022, 11:25:57 PM
Re: making walls invissible
The 3D view modification pane lets you change the transparency of the walls.
Posted by KelvinUceta at Nov 30, 2022, 5:10:43 AM
Hi @michielper,
I don't get why do you want walls if you don't want them to be visible anyway!
Do you want to prevent walls from crossing over the roof? If that is the case, you could work with sloping walls and create the angle of the tilted roof.
Dubito, ergo sum
Mobo: ASUS TUF GAMING Z690-PLUS
CPU: Core i9-12900K
RAM: 32 GB DDR4 3200 Ghz
GPU: MSI GeForce GTX 1660 SUPER 6G
OS: Win 11 Pro
3D: SH3D 6.6.1 and Blender
Posted by Daniels118 at Nov 30, 2022, 10:36:48 AM
I think you're using the word "roof" to refer to ceiling. You are using walls to fine control the ceiling slope, but these walls are just control knobs, you don't want them visible. Am I right?
The best option is to throw away walls and ceiling and move to a real roof using the Roof generator plugin:
http://www.sweethome3d.com/support/forum/viewthread_thread,11330
If you still prefer to use walls, look at the second point of this post:
http://www.sweethome3d.com/support/forum/viewthread_thread,11933#55677
Posted by michielper at Nov 30, 2022, 2:21:20 PM
Hi Daniels118,
Yes you are right, I should have used the word "ceiling", not "roof" although I do indeed need a roof as well. I do have a Roof plugin but as far as I have seen, it does give a nice sloping roof but it does not give me a sloping ceiling.
I will check out the two links you sent.
Posted by Daniels118 at Nov 30, 2022, 3:08:02 PM
The flat ceiling generated by the Roof generator plugin is actually a room; just delete this room and you will be able to see the sloped roof faces from below.
Posted by michielper at Dec 3, 2022, 2:04:38 PM
smile   Re: making walls invissible
Indeed! This is the best solution for my problem. Thanks for the tips!
Posted by DerekvG at May 14, 2023, 4:58:48 PM
Re: making walls invisible/transparent part2
This makes all the walls transparent,
the other way is to change the height of the wall in Ctrl-shift-E modify wall
would it be a suggestion to be able to select a wall and make it transparent such that the user can work on the other walls furniture inside?
Posted by Daniels118 at May 14, 2023, 5:32:03 PM
Take a look at this:
https://youtu.be/wYDrdH8brsw
Posted by DerekvG at May 14, 2023, 6:25:25 PM
nice looks very good at what i want to achieve
