Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: higher stuff obscured by lower stuff |
| Print at Sep 27, 2026, 7:37:52 AM |
| Posted by Keet at Dec 17, 2022, 9:24:30 AM |
Re: higher stuff obscured by lower stuff ... I created what will be a physical wall inside the regular room walls (using several box objects for the various components) so that I could plan the placement of studs, plates, and sheetrock along one side of a staircase in my basement. In carpentry a plate is a 2x4 or larger length of wood that's laid horizontally on its side at the bottom and top of a wall. The vertical studs go between them and connect them... You might be interested in the Dimensional Lumber library that offers lumber objects for that sort of construction.---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by DaveLab at Dec 18, 2022, 1:07:58 AM |
Re: higher stuff obscured by lower stuff Good thought. Lemme give that a go. Thanks! ---------------------------------------- DaveLab Somewhere in western Massachusetts |
| Posted by DaveLab at Dec 18, 2022, 1:09:44 AM |
Re: higher stuff obscured by lower stuff My last reply was for the grouping suggestion. As for the dimensional lumber library: wow. Can't wait to check that out. Thanks. :) ---------------------------------------- DaveLab Somewhere in western Massachusetts |
Current timezone is GMT Sep 27, 2026, 7:37:52 AM |
