Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Stairs don't reach the wall height |
| Print at Sep 26, 2026, 3:57:25 AM | |
| Posted by FlaStorm32 at Dec 25, 2022, 4:05:21 PM |
Stairs don't reach the wall heightI created a 2-level structure with doors on the second level. 8 foot walls. When I try to add the Exterior Stairs, they do not match the wall height. When I adjust the height, I get huge railings. A straight stair will fit correctly, but I need the landing at the top. https://postimg.cc/Nyw6wNP5 Thanks! |
| Posted by FlaStorm32 at Dec 25, 2022, 4:35:32 PM |
Re: Stairs don't reach the wall height I tried the staircase generator, but it doesn't allow for an upper landing. Otherwise, the stair fit well enough. |
| Posted by kawal at Dec 26, 2022, 6:30:46 AM |
Re: Stairs don't reach the wall height I also had the same problem. I made every step of the stair and landing manually using the box. I picked the box, kept the length 36", thread 10" and riser 6" and with different elevation for every stair I built my own and later grouped all together. |
| Posted by cadilhac at Jan 3, 2023, 5:19:29 PM |
Re: Stairs don't reach the wall height The Staircase Generator does have an option for staircase with landing, doesn't it? Tweaking the numbers therein, you can put the landing at the top: ![]() |
| Posted by FlaStorm32 at Jan 4, 2023, 1:13:27 AM |
Re: Stairs don't reach the wall height Straight with Landing showed me a Bottom landing, so I passed it up. Will have to work with it more. Thanks! |
| Posted by MichaelS1950 at Apr 8, 2024, 8:56:26 PM |
Re: Stairs don't reach the wall height Hello, Newbie here. Just bought the software today. I'm looking for a stair with a landing almost like the picture except with the rail on one side. My question is where do I find the stair generator? Is it an add on? Thanks very much. |
| Posted by Puybaret at Apr 9, 2024, 12:46:36 PM |
Re: Stairs don't reach the wall height The Staircase generator is a plug-in available here. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 26, 2026, 3:57:25 AM |
