Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: errors importing or installing plugins |
| Print at Sep 23, 2026, 9:52:57 PM | |
| Posted by Lysakowski at Jan 9, 2023, 9:21:35 AM |
errors importing or installing pluginsI get the same error message when trying to import .sh3p files, error importing or installing plugin: "Can't import plug-in "c:\users\poweruser\desktop\home_renovation\sweethome3d\models-various\evidencemarkergenerator-1.1.sh3p" I am running SweetHome 3D version 7.0.2 on Windows 10 Professional. I have tried with the following plugin files: StaircaseGenerator-1.0.sh3p GenerateRoof.sh3p ExportPlanImage-1.0.sh3p and others. Do the files need to be in a specific directory? I am importing them from my working directory. .sh3p files are supposed to be native SH3d files aren't they? I try double-clicking on the .sh3p files and still get the message above. If I use the menu "Furniture... Import... " and then either select a file or drag-and-drop a file. I get errors with .sh3p, .zip, and .obj files. I am new to SH3D, so this is frustrating my effort to get my construction renovation project done. |
| Posted by Puybaret at Jan 9, 2023, 4:21:22 PM |
Re: errors importing or installing plugins You probably haven't the right to write in the folder where plug-ins are stored. Can you try to place these plug-ins in the folder C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D\plugins (where user is your login) and restart Sweet Home 3D? .sh3p files are supposed to be native SH3d files aren't they? What do you mean by "native"?If I use the menu "Furniture... Import... " and then either select a file or drag-and-drop a file. I get errors with .sh3p, .zip, and .obj files. Import menus are not used to install plug-ins.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Lysakowski at Jan 9, 2023, 10:34:57 PM |
Re: errors importing or installing plugins I installed with full administrator privileges. There is no folder named: "C:\Users\<<user>>\AppData\Roaming\eTeks\Sweet Home 3D\plugins" I found these eTeks related folders: "C:\Users\PowerUser\eTeks" (EMPTY) "C:\Users\PowerUser\eTeks\Sweet Home 3D\recovery" (EMPTY) All the subfolders in this parent folder are EMPTY: "C:\Users\PowerUser\AppData\Local\Packages\eTeks.SweetHome3D_y7v7etvrysvmm" "C:\Users\PowerUser\AppData\Local\Packages\eTeks.SweetHome3D_y7v7etvrysvmm\AppData" I first did a portable installation of the free version (from SourceForge), and then I installed the version from the Microsoft Store, and I cannot (yet) find where the Microsoft Store version is installed. I hate using the Windows Store because it hides things away from users. After the Microsoft Store installer, I am still not able to install the plugins, because I cannot find the plugin directory. By the way, "native" format means the file format(s) that are native to an application, e.g., sh3d for SweetHome 3D, xlsx for MS-Excel, docx and doc for MS-Word. These are also the file extensions that get registered by the Windows operating system in the Windows Registry. Is there a way to download the "Pro" (paid) version and install it manually without using the Windows Store? |
| Posted by Puybaret at Jan 12, 2023, 9:00:19 AM |
Re: errors importing or installing plugins There is no folder named: Create it yourself and place some .sh3p files in it."C:\Users\<<user>>\AppData\Roaming\eTeks\Sweet Home 3D\plugins" ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by saitama_hadumsky at Dec 8, 2023, 12:10:18 PM |
Re: errors importing or installing plugins hi, I have almost the same problem, but I don't get an error message, and the plugins just don't work, I click on tools, click on the plugin and it doesn't work |
Current timezone is GMT Sep 23, 2026, 9:52:57 PM |
