Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Trying to install SH3F under Ubunu (Linux) |
| Print at Sep 24, 2026, 10:08:31 AM | |
| Posted by hansmex at Dec 14, 2009, 11:40:32 AM |
Trying to install SH3F under Ubunu (Linux) Hello all :-) I'm trying to install the SH3F-plugin, so that I can export my libraries. After downloading the plugin I searched for the .eteks directory. Not being able to find it, I created a directory under the "Home Folder" that I called ".eteks", then a subdirectory called "sweethome3d" then one called "plugins". I placed the "com"-folder in that last folder. I then started up SH3D but under "Furniture" there was no "export" option. I copied the files in the "exportsh3f" directory into each directory from ".eteks" down, but still SH3D doesn't show the 'export" option. What am I doing wrong?? Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Dec 14, 2009, 9:20:02 PM |
Re: Trying to install SH3F under Ubunu (Linux) To ensure you created the directory at the place, try this tip: Import an existing SH3F file with Furniture > Import furniture library... menu item. This will create .eteks/sweethome3d/furniture subdirectory in your home directory with the imported SH3F file in it. Go to the .eteks/sweethome3d directory, create a subdirectory name plugins in it and copy the ExportToSH3F-1.0.sh3p file into plugins subdirectory. Finally, relaunch Sweet Home 3D. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Dec 14, 2009, 10:30:51 PM |
Re: Trying to install SH3F under Ubunu (Linux) Emmanuel, Once again, thank you very much for your help. I created the directory in the right spot, but I placed the unzipped files in it. It turns out that the SH3F-file must be in that directory. I hope to be able to post some files soon. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 24, 2026, 10:08:31 AM |
