Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: "Create photo" crashes |
| Print at Oct 11, 2026, 9:46:10 AM | |
| Posted by millennium_y2k at Jan 16, 2023, 1:59:41 PM |
"Create photo" crashesIn my version 6.1.1 when I go to create a 3D photo of the house, full resolution, I click on "Create", the rendering starts, but at a certain point it stops, without errors... what can it depend on? |
| Posted by Puybaret at Jan 16, 2023, 3:43:12 PM |
Re: "Create photo" crashes Maybe, your SH3D file is too large or the program doesn't have enough memory to create the image. See the FAQ to increase the maximum memory Sweet Home 3D can use, but if you use the 32 bit version (see About dialog box), try first the 64 bit version by running again the installer. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by millennium_y2k at Jan 16, 2023, 4:29:12 PM |
Re: "Create photo" crashes i use a mac bok, the file is layered and weighs 60mb, but when i did it 1 year ago, everything was fine... |
| Posted by millennium_y2k at Jan 16, 2023, 4:42:44 PM |
Re: "Create photo" crashes I'm also trying with the latest version, 7.0.2, but a red X comes out in the preview... do i need to install anything else, maybe java? |
| Posted by Puybaret at Jan 16, 2023, 5:35:50 PM |
Re: "Create photo" crashes No need to install Java. You certainly changed something. Maybe try another renderer (YafaRay instead of SunFlow). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by millennium_y2k at Jan 17, 2023, 10:24:08 AM |
Re: "Create photo" crashes The project is from 1 year ago, done on another MAC. I'm not sure if I imported all libraries with objects, could that be it? The render both with YafaRay and with SunFlow, doesn't start, it shows the red X or nothing.. I tried both on MAC and on Win11. Is there any way to know if libraries are missing (if this were the case)? THK ! |
| Posted by Puybaret at Jan 17, 2023, 12:02:00 PM |
Re: "Create photo" crashes A SH3D file contains everything it needs to be displayed and rendered. Send me your file, I'll have a look to it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by millennium_y2k at Jan 17, 2023, 2:49:01 PM |
Re: "Create photo" crashes Email send |
| Posted by Puybaret at Jan 18, 2023, 9:59:41 AM |
Re: "Create photo" crashes Thanks for your file. I didn't experience any crash during the rendering of your file with SunFlow or YafaRay renderers, but I had to be very patient before YafaRay starts. For sure, it needs a lot of memory to render it, because of the items named "prato" showing many grass blades. If you don't have the patience to wait or increase the max memory, you could replace these items by rooms showing a grass texture. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by millennium_y2k at Jan 18, 2023, 11:53:34 AM |
Re: "Create photo" crashes Thanks a lot, I will try with your suggestion! |
Current timezone is GMT Oct 11, 2026, 9:46:10 AM |
