Print at Oct 7, 2026, 3:13:59 PM
Posted by k005 at Jan 23, 2023, 7:04:12 AM
Making a hole in the wall
Hi all,
I want to open a space of 140x140cm on the wall.
How can I do that ?
Thanks to my helpful friend.
Posted by Keet at Jan 23, 2023, 7:56:17 AM
Re: Making a hole in the wall
The quickest and easiest way is to simply use a service hatch adjusted to the size you want.
Posted by k005 at Jan 23, 2023, 8:00:28 AM
What is a service cover? I did not get it.
Posted by Keet at Jan 23, 2023, 8:20:53 AM
A service hatch is a "window" in the category doors and windows. Drag it in the wall and it acts like a door or window but is just a square that creates a hole. You can adjust it's size and elevation like any other window.
Posted by Puybaret at Jan 23, 2023, 8:29:53 AM
You could also read these tips which are based on the same idea:
How to create a hole at the bottom of a wall
How to design wall recesses
How to show interior parts hidden by walls
Posted by k005 at Jan 23, 2023, 8:55:04 AM
Thank you. Ok. @Keet
Posted by k005 at Jan 23, 2023, 8:56:48 AM
@Puybaret
Thank you. Ok. I'm examining.
