Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Silent Installation with 64bit dont work |
| Print at Sep 23, 2026, 5:03:57 PM | |
| Posted by Jeypee at Jan 30, 2023, 1:48:20 PM |
Silent Installation with 64bit dont workHello, today i tried to install the newest Version 7.0.2 over command line in 64 bit. All Parameters are visible with "SweetHome3d-7.0.2.exe" /? First i started with the parameter "/SAVEINF="SweetHome3D.inf" Installed in "64-bit" - all ok. After that i uninstalled it. Next i tried with "/loadinf="SweetHome3D.inf" but it installed in "C:\ProgramFiles (x86)" < 32 bit. In the Inf File is an Parameter: Dir="C:\Program Files\Sweet Home 3D" I also tried with "/DIR="C:\Program Files\Sweet Home 3D" but it installed also in the 32-bit Directory ?! My Problem is that no silent installation works. Here my parameter: SweetHome3d-7.0.2.exe /SILENT /NORESTART /NOCANCEL /DIR="C:\Program Files\Sweet Home 3d" /LOG="SweetHome3d.log" Dont work - just 32-bit. Only manuel 64-bit works :-( Please help |
| Posted by Puybaret at Jan 31, 2023, 7:09:52 AM |
Re: Silent Installation with 64bit dont work Adding /os.arch=x64 parameter should do the trick. See also installer parameters described at the end of this article. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Jeypee at Jan 31, 2023, 8:52:03 AM |
Re: Silent Installation with 64bit dont workThank you very much. That works. Should be stay here: http://www.sweethome3d.com/faq.jsp#installation ![]() |
Current timezone is GMT Sep 23, 2026, 5:03:57 PM |
