Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Bedroom wing on raised level |
| Print at Oct 6, 2026, 11:10:00 PM | |
| Posted by Havouza at Feb 9, 2023, 10:55:34 AM |
Bedroom wing on raised level Hi! We live in a L-shaped bungalow. The bedromms are in the "foot" of the L. Thisa part is 0.5 m above the rest of the house. The outer walls are all of the same hight so the hight between the floor and the celing is 0.5 m lower in this part. Is there a way I can contruct this in the program? Hope someone can understand what I mean Anders |
| Posted by Puybaret at Feb 9, 2023, 11:08:11 AM |
Re: Bedroom wing on raised level You could create two levels, and set the height of the second level 0.5 m less high than the height of the ground level. Reading this tip should help you too. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 6, 2026, 11:10:00 PM |
