Print at Sep 23, 2026, 9:52:52 PM
Posted by SoapSpoon at Apr 4, 2023, 4:29:35 PM
When adjusting wall thickness, make it possible to select in which direction the wall should expand
We have had serious issues with wall thickness in Sweet Home 3D:
First, the good: If you create an entire room from interior dimensions and then double-click the room to add walls, the walls are added, with default thickness, to the OUTSIDE of the room, without impacting the measured room size. Great.
However, if later I want to adjust wall thickness - for example increate it by 10cm - half of the increment (5cm) is put on the inside of the room and the other half (5cm) is put on the outside. Thus, the expanded wall thickness essentially "eats" into the established room dimensions, and the interior dimensions no longer fits the measurement as it is now 5cm shorter than before (and, if there is a neighbouring room, that one is 5cm shorter too).
I get that this can't be automated as SH3D has no idea in which direction to expand the wall, but it should be possible to add an option, when adjusting wall thickness, which could have three options: (A) Expand half on each side, (B) Expand into North/East, (C) Expand into South/West.
(North/South would be for walls going horizontally across the computer screen, East/West for the vertical ones. Maybe it could be phrased better, or even visualized on-screen to avoid confusion).
Ideally there should be something similar for shrinking walls, although I'm not sure what would be smartest there as you obviously don't want gaps between rooms...
Posted by Keet at Apr 5, 2023, 10:49:59 AM
Re: When adjusting wall thickness, make it possible to select in which direction the wall should expand
Adding such options would make a mess of the wall options: it adds options rarely used, solving a problem that can be solved in other ways.
If you create a room from the inner dimensions you probably also know the wall dimensions. It's easier to manipulate walls than a room so start with the walls, positioning them so the inner dimensions fit, and then fill in the room.
If you really need to adjust the wall thickness without changing the inner dimensions I suggest you use the options to move a wall after adjusting the thickness. I think it's the AdvancedEdit plugin that offers a menu item for moving objects. If you increased the wall thickness with 10 you move it with 5.
You can also move a wall by changing the X and Y coordinates in the Wall properties window. I you need to move a wall up or down adjust both Y coordinates, for left or right adjust both X coordinates.
Posted by dorin at Apr 6, 2023, 6:57:34 AM
For this purpose I've write this mini tutorial .
