Print at Sep 24, 2026, 12:51:36 AM
Posted by daytooner at Apr 14, 2023, 1:32:59 AM
Errors creating plugin class
I have followed the instructions here: https://www.sweethome3d.com/pluginDeveloperGuide.jsp to generate a basic plugin. But when I generate the VolumePlugin class, I get the error:
"The type com.eteks.sweethome3d.plugin.Plugin is not accessible"
Here is the code that was generated:
package com.eteks.test;
import com.eteks.sweethome3d.plugin.Plugin;
public class VolumePlugin extends Plugin {
Did I miss something?
TIA
ken
Posted by Puybaret at Apr 14, 2023, 2:03:46 PM
Re: Errors creating plugin class
You probably use a compiler compliance level ≥ 9.
Change compiler compliance level to 1.8 in project properties or maybe accept Eclipse's quick fix Add 'requires SweetHome3D' to module-info.java
