Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Light rays in foggy air? |
| Print at Oct 15, 2026, 4:42:36 AM | |
| Posted by Soulbrother at Apr 14, 2023, 11:19:59 AM |
Light rays in foggy air? Dear all! I have a few questions about light and rendering. 1. is there a way to make light rays visible in the air after rendering? So similar to soft fog. I think this effect should be strongest with hard sunlight. In stage lighting (concerts, theatres, etc) you can also see this well with spotlights in combination with hazers (fog machines for thin fog). 2. Are there also (artificial) light sources that offer a similar hard and focused light as very narrow spots, i.e. only a few degrees of exit angle. 3. are there even more extreme light sources such as laser light? Thanks again for all your hints and tricks :-) |
| Posted by Puybaret at Apr 14, 2023, 2:09:21 PM |
Re: Light rays in foggy air? You should probably look for the miracles performed by Cecilia explained in her interview and other places in the forum like in this subject. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 15, 2026, 4:42:36 AM |
