Print at Sep 30, 2026, 1:47:29 AM
Posts: 15   Pages: 2   [ Previous Page | 1 2 ]
Posted by Gildaniel at Oct 22, 2023, 9:44:43 PM
Re: Second (sometimes even first) instance of SH is not starting
Nope, there is no eTeks folder neither in users, nor anywhere on ssd.
Posted by Vinci68 at Oct 23, 2023, 3:33:02 PM
For my part, I had moved the program instances to partition D: when I partitioned my disk:
As a result, I found this folder by following this path :
D:>Documents>My_UserName>AppData>eteks>Sweet Home 3D
Perhaps a clue for you !
Posted by Gildaniel at Oct 23, 2023, 4:27:12 PM
Bingo, thank you!
I have the log in /users/myusername/appdata/roaming/eteks
So, here is the log when I have one file opened and try to open second one (and nothing happens)
https://woodmouse.ru/test/log-nosecondinstance.txt
Posted by Daniels118 at Oct 23, 2023, 4:49:25 PM
Hi Gildaniel, this is a known bug of an old version of Pan3dView plugin. Which version are you using? Try to update to a newer one.
See https://www.sweethome3d.com/support/forum/vie...read,5072_offset,80#57000
Posted by Gildaniel at Oct 23, 2023, 7:33:44 PM
Daniels118, thank you very much, I updated the plugin and now everything is ok!
