Print at Oct 4, 2026, 10:08:50 PM
Posted by Soulis at May 8, 2023, 5:51:03 AM
confused   Raising a floor up
So, I am trying to elevate the floor to 3' (feet), basically making it a stage. How do I do that without creating a second level?
Do villains see themselves as saviors, as would a hero? Based on the fact that most comic book villains (e.g: Marvel/DC) their motives are that they are trying to save or right some wrong. So are they really villains, anti-heroes or Anti-Villains?
Posted by hansmex at May 8, 2023, 10:24:54 AM
Re: Raising a floor up
1 - insert a box that has the dimensions and elevation of your stage
or
2 - draw a room that has the dimensions of your stage - export and import as furniture - you can now adjust the elevation
Posted by Soulis at May 11, 2023, 10:09:20 AM
Okay I am going to attempt this but I am not sure I fully understand fully what you are saying wish me luck Xing my fingers
Posted by Soulis at May 16, 2023, 5:49:36 AM
I tried that but it is not giving me the option to do any of the exporting.
Posted by hansmex at May 16, 2023, 6:41:56 AM
Have a look at this example that uses a box to simulate a raised floor.
https://www.mediafire.com/file/35wzc8o1nqliw9...sed+floor+w+box.sh3d/file
Posted by Soulis at May 20, 2023, 8:44:24 PM
Is it that file you put on my other question?
Posted by Keet at May 22, 2023, 10:47:46 AM
I don't know why you don't want to use a second level. It has several advantages like being able to show/hide just the stage level and objects you place there are automatically on the level of the stage. Another advantage is that if you want to adjust the height of the stage you just have to adjust the height of the stage level and everything on it will go along with the changed height. The beauty is that you can create a stage level with a 3' elevation and a floor thickness of 3' and your floor is now the stage smile
Without using an extra level do what Hans said: create a box the size of your stage and place it where you want. If the stage is 3' high you need to elevate everything you want to place on the stage by 3' too.
