Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Installing 3d content |
| Print at Oct 2, 2026, 11:33:46 AM | |
| Posted by Soulis at May 24, 2023, 4:34:38 PM |
Installing 3d contentHow do I install the 3d object files into sh3d? ---------------------------------------- Do villains see themselves as saviors, as would a hero? Based on the fact that most comic book villains (e.g: Marvel/DC) their motives are that they are trying to save or right some wrong. So are they really villains, anti-heroes or Anti-Villains? |
| Posted by Puybaret at May 24, 2023, 5:13:22 PM |
Re: Installing 3d content Follow the guide! This video may help you too. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Keet at May 25, 2023, 7:37:21 AM |
Re: Installing 3d content One feature not mentioned in the guide is that you can drag-and-drop an object file from a file browser into the Sweethome3D 2D window to import it. This is the method I always use instead of the import through the menu because it's easier and faster and most important: you can drop at the position you want and avoid the default 0,0 position. Another advantage is that you can select multiple object files and drag them all at once into the 2D window. For each file you get the import wizard and all at the position where you drop them. Works perfectly! Unfortunately this method doesn't work with furniture libraries (.sh3f files) but maybe that will be fixed in a future version. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 2, 2026, 11:33:46 AM |
