Print at Oct 8, 2026, 10:38:39 AM
Posted by franz2b at May 28, 2023, 2:36:18 PM
HELP // 2D plan hidden and stuck in bottom right
Hello,
Spent like hours for fixing this.
How to center my 2D plan ?
Video of the matter here
Thank you very much
Posted by kawal at Jun 1, 2023, 8:16:58 AM
Re: HELP // 2D plan hidden and stuck in bottom right
is it possible for you to share the .sh3d project file?
Posted by hansmex at Jun 1, 2023, 8:31:57 AM
- install plugin AdvancedEdit
- select all on all levels
- use Move-function to re-position yout design
Posted by Keet at Jun 1, 2023, 8:48:45 AM
This happens because Sweethome3D starts with a limited view of the 2D plan and no scrollbars. Sometimes a part of the project is not shown at all when it's some distance form the part you see. I use a trick to get a full view and scollbars:
First install the Pan3dView plugin.
Open your project and pick a random object and make it large enough to comfortably click and drag. Zoom out and drag the object left, right, up, and down. You will see the window scroll and scrollbars appear. Move as far in any direction you want and when done delete the object you used.
Now place your mouse pointer at the center you want to zoom to and use Ctrl+MouseScroll to zoom in. You can also use Shift+MouseScroll to pan left and right.
Posted by Keet at Jun 1, 2023, 8:53:57 AM
What Hans mentioned is also a possibility: your project isn't centered at the 0,0 coordinates. His solution works too (partially) if you can place your project at the 0,0 position.
My solution works when you are way of the 0,0 position which I often have to do: I work with very large projects that span kilometers. To keep it manageable I develop parts in separate projects at the position they have in the merged project and that can be a long way off from 0,0. My trick to enlarge the 2D field then works like a charm.
