Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: 3D vision is semi-transparent |
| Print at Sep 29, 2026, 11:22:05 AM |
| Posted by PMjf at Jun 2, 2023, 10:30:51 AM |
Re: 3D vision is semi-transparent The problem is not in your program. Sh3D works perfectly. The problem is my laptop. Sh3D generates OPENGL code correctly but wrong transparency code arrives on the graphics card. It is normal in windows, problem, problem, problem. |
| Posted by Puybaret at Jun 9, 2023, 8:30:14 AM |
Re: 3D vision is semi-transparent Then, please try Sweet Home 3D version with runs with DirectX as explained in the FAQ, i.e. install again the 32 bit version of Sweet Home 3D, download the file SweetHome3D.l4j.ini, copy it in Sweet Home 3D installation folder (probably C:\Program Files (x86)\Sweet Home 3D) and relaunch Sweet Home 3D. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by PMjf at Jun 13, 2023, 5:09:33 PM |
Re: 3D vision is semi-transparent Problem solved. I have returned my laptop to factory settings and updated to Windows 11. Thanks |
Current timezone is GMT Sep 29, 2026, 11:22:05 AM |
