Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Fix My Wonky Corners |
| Print at Oct 1, 2026, 5:16:35 AM | |
| Posted by MartinWinlow at Jun 15, 2023, 9:49:11 AM |
Fix My Wonky Corners Hi, I have this wall intersection... ![]() ... and I want this: ![]() Any ideas? Whenever I try to extend the big wall to make a proper corner with the small wall emerging from it it reverts back to pic1... MW |
| Posted by Keet at Jun 16, 2023, 6:15:13 PM |
Re: Fix My Wonky Corners Join the two thicker walls and then touch the smaller wall to the others. To make a correct corner you don't extend a wall but you join the two walls: select the two walls, right click for the context menu, choose "join walls". ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by MartinWinlow at Jun 17, 2023, 9:19:55 AM |
Re: Fix My Wonky Corners Hi, Thank you for your help but when I right click I get no option to 'jon' (I am using the OSX version of SH3D, tho). Is there a way to 'properly jon walls' using the menu? I've tried the Help and it doesn't... MW |
| Posted by Keet at Jun 17, 2023, 10:55:41 AM |
Re: Fix My Wonky Corners Make sure you have selected the two walls you want to connect , then right click for the context menu which should have the option 'Join walls'. My guess is that you didn't have two walls selected before the right click. The two walls don't need to touch and can be some distance from each other. Sweethome3D will calculate the two nearest wall ends, extend the walls, and connect them into a corner. The walls don't need to be in a 90° angle. You can also connect walls to close a gap between walls. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by MartinWinlow at Jun 17, 2023, 12:35:28 PM |
Re: Fix My Wonky Corners Indeed... So, this is what I get:- ... no 'Join Walls'... MW |
| Posted by Keet at Jun 17, 2023, 1:13:16 PM |
Re: Fix My Wonky Corners Are you sure that is a screenshot from Sweethome3D? Because it looks quite different from my install. What gave it aways is the "Make invisible" in the context menu. You can't make walls invisible in Sweethome3D. I don't think there is any context menu in Sweethome3D with "Make invisible". So I assume that is a context menu from a different program. I also don't see that two walls are selected. For your corner you should select the two thick walls to join (top left and vertical). In Sweethome3D of course. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by MartinWinlow at Jun 17, 2023, 1:15:02 PM |
Re: Fix My Wonky Corners Oops! Started with Sweethome and ended up with Live Home 3D. Sorry to have wasted your time... |
| Posted by Keet at Jun 17, 2023, 1:25:34 PM |
Re: Fix My Wonky Corners Ah, I thought so. Nice program but totally useless for me since there's no Linux version and all my machines are Linux, even my phone is Linux (not Android).---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 1, 2026, 5:16:35 AM |
