Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Object surfaces reflect environment? |
| Print at Sep 26, 2026, 4:47:39 PM |
| Posted by Daniels118 at Jul 3, 2023, 3:16:13 PM |
Re: Object surfaces reflect environment? Have you tried this? Also remember that you can change the shininess of materials from the furniture modification dialog, and export the object to check what changes in the mtl file. |
| Posted by selden at Jul 3, 2023, 5:41:16 PM |
Re: Object surfaces reflect environment? For some reason I thought one could not export one of the "in use" objects.... Unfortunately, I can't find that option (to export a furniture object) *sigh* must be another item that's right in front of me. ---------------------------------------- Selden |
| Posted by selden at Jul 3, 2023, 5:45:32 PM |
Re: Object surfaces reflect environment? There's an "export to csv" but that just exports the list of in-use objects... and it's actually an "export to TAB separated values", not "Comma separated values" ---------------------------------------- Selden |
| Posted by Daniels118 at Jul 3, 2023, 6:26:26 PM |
Re: Object surfaces reflect environment? The export command is in the 3D view menu. You have to select the object to export first. You may also use this function to merge 2 or more objects. |
| Posted by selden at Jul 3, 2023, 9:26:00 PM |
Re: Object surfaces reflect environment? Oh. Of course. I've even used it a kajillion times. *sigh* Anyhoo... I did a save-to-obj for the object both when it was reflective and when it wasn't. The only difference between the matt .mtl and the reflective .mtl is the Ns value. Reflective: =================== newmtl brown illum 2 Ka 0.2 0.2 0.2 Kd 0.533 0.4 0.267 Ks 0.0 0.0 0.0 Ns 128.0 =================== NON-reflective: =================== newmtl brown illum 2 Ka 0.2 0.2 0.2 Kd 0.533 0.4 0.267 Ks 0.0 0.0 0.0 Ns 1.0 =================== ---------------------------------------- Selden |
| Posted by selden at Jul 3, 2023, 10:04:31 PM |
Re: Object surfaces reflect environment? Fortunately, it turns out that an NS of 0.0 works just as well as 1.0 I've been using Anim8or to create my obj models. Ns seems to be controlled by a combination of Anim8or's material values of "Rough" and "Brilliance". Setting them both to 1 yields an Ns of 0.0 ---------------------------------------- Selden |
Current timezone is GMT Sep 26, 2026, 4:47:39 PM |
