Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Model icons in Furniture Library Editor are black squares |
| Print at Sep 29, 2026, 5:15:33 PM | |
| Posted by [email protected] at Jul 13, 2023, 8:08:08 PM |
Model icons in Furniture Library Editor are black squares Hello, I am trying to create a furniture library with Furniture Library Editor. The problem I have is that after importing a model to a library (downloaded for example from this page https://sweethome3d.com/freeModels.jsp), it does not have an icon. Instead a black square is shown. After saving the library to a sh3f file and then extracting it, the png file which I suppose should be an icon is a black square. If I add say 50 models to the library, save it and then extract, I will have 50 identical png files with exact same content (black square), and the only difference will be the name reflecting the name of the model. I am new to this great application so I do not know if I should provide the icon for the model, or it should be auto generated by the Editor. Marek |
| Posted by hansmex at Jul 14, 2023, 7:25:53 AM |
Re: Model icons in Furniture Library Editor are black squares I have (had) a similar problem, where the image of imported models in the furniture catalogue was a black square or a black inverted L. The solution for me is to select the model in the catalogue list, sselect Modify Furniture and then slightly rotate the preview image. I then click through the rest of the dialogue (Continue and Finish) and there appears a new preview image without the black square. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by [email protected] at Jul 15, 2023, 7:19:38 PM |
Re: Model icons in Furniture Library Editor are black squares Is the process you described for Sweet Home 3d main app or Furniture Library Editor? Marek |
| Posted by Keet at Jul 15, 2023, 7:38:02 PM |
Re: Model icons in Furniture Library Editor are black squares I've had the same problem and just moving the image a little works in both the furniture library editor as well as in Sweethome3D when importing/changing an object. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 29, 2026, 5:15:33 PM |
