Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Apartment project with lighting by invisible hemispheres. I continue advertising |
| Print at Sep 30, 2026, 2:31:42 AM |
| Posted by Vilgard at Nov 8, 2023, 9:12:00 AM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising Hi. I can't find the "luminous half-sphere" on my SH3D version 7.2... There is a reason for this ? Do I need to install a special plugin ? Salut. Je ne trouve pas la "demi-sphère lumineuse" sur mon SH3D version 7.2... Il y a une raison à cela ? Faut-il installer un plugin spécial ? |
| Posted by Puybaret at Nov 8, 2023, 10:26:20 AM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising You'll find this light source in the LightShapes.sh3f furniture library explained in the blog article about Sweet Home 3D 7.0. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Vilgard at Nov 8, 2023, 3:13:41 PM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising thank you, that’s what I was missing ![]() |
| Posted by GaudiGalopin3324 at Nov 8, 2023, 7:30:53 PM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising ![]() |
| Posted by GaudiGalopin3324 at Nov 8, 2023, 7:50:19 PM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising I've simplified the lighting even more. I placed multicolored hemispheres 110x110x254cm with a capacity of 2.5% in the room. The separation from the floor is 7cm, from the ceiling is 3cm (ceiling height is 264cm). Wider hemispheres give a more even illumination of the ceiling, even with a rare arrangement of hemispheres. On the street, at the level of the upper edge of the windows, I placed blue spheres stretched horizontally, wider than the size of the window. The size of these spheres is 300x65x65cm, the power is 30%. And that's it! No panels. Only chains of orange balls for diode illumination. If there are no heavy models in the room, then as 2000x1500 a picture with a good realistic view is loaded for 6-9 hours. It all depends on the severity of the models that fall into the frame. Hemispheres can be safely placed as you like, intersect walls and objects - nothing appears at low power, everything is smooth, without spots (only you need to put YAFARAY). Experimented with a new way of textures for the sofa and armchair. If you take any texture of the desired overall color and assign a texture scale of 1-2% in furniture, then you get an even CORDUROY in color. A good way to get furniture without strange stains and in an interesting material. |
| Posted by GaudiGalopin3324 at Nov 8, 2023, 8:04:37 PM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising all the lights are arranged like this |
| Posted by GaudiGalopin3324 at Nov 8, 2023, 8:25:59 PM |
| Posted by GaudiGalopin3324 at Nov 10, 2023, 6:09:19 PM |
| Posted by GaudiGalopin3324 at Nov 10, 2023, 6:22:38 PM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising![]() |
| Posted by GaudiGalopin3324 at Nov 17, 2023, 4:16:13 PM |
Current timezone is GMT Sep 30, 2026, 2:31:42 AM |
