Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Open GL error trying to launch |
| Print at Oct 3, 2026, 8:08:45 PM | |
| Posted by popifresco at Sep 8, 2023, 8:57:19 PM |
Open GL error trying to launch Well, I think this is a classic error for what I've reading here. There are 1000 possible fixes and I tried them all and the error persist. When I launch the application it opens normally and before I can do anything there is a popup saying "there is a problem related to DirectX/OpenGL, update your drivers blabla..." (can't reproduce the exact message in english because it's written in spanish, the language I use. I reinstalled the software in english and the popup is still in spanish) I know there are a lot of threads about this with different solutions, but as I say I tried them all. I spent many many hours trying to fix this with no luck. The program worked well with my old PC with an AMD RX480 in Windows 10 but now I have an Intel i5 12600k with a Nvidia RTX3060 (Win 10 also) and I can't run it... Of course all my drivers are up to date. I'm really desperate, could you please, anyone, give me any possible solution? Thanks!!!!! |
| Posted by Puybaret at Sep 9, 2023, 8:02:25 AM |
Re: Open GL error trying to launch Check if you run the 32 bit version of the program by looking at the About dialog box. If it’s the case, run the installer again and select 64 bit architecture when prompted. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by azuya at Sep 15, 2023, 5:46:53 PM |
Re: Open GL error trying to launch Hi, i´ve tried all posible fixes too and have no changes. the error still appears. Changing to 64 bits doesn´t resolve anything ( at least in my case) |
| Posted by Puybaret at Sep 15, 2023, 7:42:34 PM |
Re: Open GL error trying to launch Try the Beta version of Sweet Home 3D 7.2. It comes with an update of JOGL, the 3D layer which uses OpenGL. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by azuya at Sep 16, 2023, 9:17:27 PM |
Re: Open GL error trying to launch i´ve just try that beta version and have the same issue. "3d fatal error.. please update directx/opengl drivers "(i´ve try with the lastest nvidia driver available) i´ve win11 system, rtx4080 and intel i5 13500 cpu... all updated.i´ve tried both 32 and 64 bits installation... in other pc, a laptop with Radeon card, worked fine and i love that program. any other clue? thans in advance |
| Posted by azuya at Sep 16, 2023, 9:22:39 PM |
Re: Open GL error trying to launch hi.. i´v just tried that fix that appear in faqs and.. works!!! thankyou very much!!! "If running Sweet Home 3D in 32 bit still doesn't work, download the file SweetHome3D.l4j.ini, copy it in Sweet Home 3D installation folder (by default, C:\Program Files\Sweet Home 3D or C:\Program Files (x86)\Sweet Home 3D) and relaunch Sweet Home 3D. The file SweetHome3D.l4j.ini tells Sweet Home 3D to use the DirectX version of the Java 3D library rather than the OpenGL version, but this option is available only in 32 bit (if you installed a JRE 32 bit, you may also click on this link to run Sweet Home 3D with Java Web Start and the DirectX version of the Java 3D library)." " |
| Posted by davidm361 at Aug 31, 2024, 8:56:09 PM |
Re: Open GL error trying to launch Me pasa lo mismo O... The same thing happens to me |
| Posted by davidm361 at Aug 31, 2024, 9:11:05 PM |
Re: Open GL error trying to launch It didn't work |
Current timezone is GMT Oct 3, 2026, 8:08:45 PM |
