Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Home Rotator Plugin |
| Print at Sep 26, 2026, 5:25:11 AM | |
| Posted by dorin at Sep 15, 2023, 4:17:34 PM |
Home Rotator Plugin I've add this thread because I think it deserve this. Reasons: 1. This is THE FIRST PLUGIN made for SH3D on 24.04 2009 by Michel MBEM 2. It is writhed very clearly and for me it is a very good example! ****** THANK YOU MICHEL !!!!****** Some historical events. Michel first description on 24.04 2009 at version 1.0: Rotates the whole plan (including walls, rooms, furniture, labels and dimension lines) clockwise or counterclockwise. Michel last description on 24.05 2009 at version 1.2:Finally, I've uploaded a new version of the plugin. Considering as true the Michel statement:This one rotates the background image as well as the rest of the plan. However, there's still a small problem that you will need to fix manually: after the rotation process is complete, you will observe that the plan and the background image are not superposed no more. So you can fix this by selecting the whole plan and dragging it so that it matches the background image again. I've tried to fix this programmatically but with no success. I will continue to try a better solution. All your suggestions are welcome. This plugin is released under the GNU GPL license; so you have the right to alter it following your needs and to redistribute it within your own package. I've update it a little.As usually for me you could find the RotateHome-1.3.sh3p at Media Fire and at Source Forge. What's new? - rotate polylines - support for multiple levels - try to find a solution to correct positions of rotated items over the background. - ToDo to rotate the labels (I forgot them )Recommendation: uninstall all previously versions. @Daniels118 You could also update the Plugin Manager to point at this version. I invite all forum users to post in this tread the comments related to this plugin. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Keet at Sep 15, 2023, 4:26:38 PM |
Re: Home Rotator Plugin Good job! The plugins are a huge increase in value for Sweet Home 3D. Thank you. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by dorin at Sep 15, 2023, 6:36:09 PM |
Re: Home Rotator Plugin Thanks Keet!! There is still room for improvement. For those who want to easy start make plugins it is a good example. I'm curios how it work on your (and others) side. P.S. I've remark your new avatar ![]() ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Daniels118 at Sep 18, 2023, 6:29:54 PM |
Re: Home Rotator Plugin @dorin I have added the version 1.3 to the Plugin Manager. |
Current timezone is GMT Sep 26, 2026, 5:25:11 AM |
