Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Remove Dimensions created (with Autodimensions Plugin) |
| Print at Sep 30, 2026, 9:39:12 AM | |
| Posted by Sisosi at Sep 18, 2023, 9:48:31 AM |
Remove Dimensions created (with Autodimensions Plugin) Is there some easy way to remove all dimensions in a plan? Right now it seems to me that i have to go through each and every dimension i added before saving the file and that there are a loooot of them. It would be really to cool if dimensions could be grouped like furniture. Thx! |
| Posted by dorin at Sep 19, 2023, 7:23:04 AM |
Re: Remove Dimensions created (with Autodimensions Plugin) Delete the Level-Dim created by Auto Dimensioning. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Sisosi at Oct 14, 2023, 10:50:15 AM |
Re: Remove Dimensions created (with Autodimensions Plugin) oh i see that a new level was added. i was always looking at the objects/groups list. it would be really good i it was possible to add layers in each storey/level. |
| Posted by Keet at Oct 14, 2023, 11:59:41 AM |
Re: Remove Dimensions created (with Autodimensions Plugin) it would be really good i it was possible to add layers in each storey/level. You can: add a level at the same elevation and you have a 'layer' for that level.---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 30, 2026, 9:39:12 AM |
