Print at Oct 5, 2026, 6:54:06 AM
Posted by PeterPoggi at Sep 23, 2023, 3:28:01 AM
Commercial Kitchen Library
I'm looking for a commercial kitchen library for our fire station, but one that specifically contains a 3 compartment free standing sink. Ideally it would have a drain platform on both the left and right sides.
Seems impossible to find. I'm hoping someone can point me in the right direction
Regards
Peter
Posted by Keet at Sep 23, 2023, 9:05:01 AM
Re: Commercial Kitchen Library
There's a commercial triple sink available here: https://free3d.com/3d-model/triple-basin-sink-7328.html but it's quite expensive. Or start with this one (much cheaper): https://www.cgtrader.com/3d-models/furniture/...ainless-steel-triple-sink
From the looks of it it shouldn't be too difficult to create this yourself.
There are multiple free models available with just the sink (without cabinet). Or find a sink with cabinet from the available free models, make everything invisible except the sink itself and then export it.
Import the sink and copy it so you have three sinks. Creating the table and feet can be done by using boxes. Create the table top by adding boxes around the three sinks. You can use the same method to add the faucet(s). Export the whole thing and import it again as a single triple sink.
Posted by captaincook at Sep 23, 2023, 12:08:42 PM
Bonjour.
Vous pouvez aussi faire une recherche sur le site gratuit archive3d.net
Sous le nom de recherche "évier" ou "sink", il y a beaucoup de choix comme dans l'exemple ci-dessous.
Mais ce n'est que 1 page sur 31 concernant les éviers.
Posted by PeterPoggi at Sep 23, 2023, 4:41:11 PM
Thank you, that's perfect. I've found LOTS of sinks, but this is the only one with THREE basins and a ledge on either side.
Posted by PeterPoggi at Sep 23, 2023, 5:18:23 PM
Thank you. Unfortunately they did not have a 3 basin sink.
Posted by PeterPoggi at Sep 23, 2023, 5:21:21 PM
Can anyone recommend a good commercial kitchen library?
