Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: "Black Screen" Running Sweet Home 3D on QEMU/KVM on AMD |
| Print at Oct 8, 2026, 4:45:36 AM | |
| Posted by LearningSH3D at Oct 3, 2023, 7:43:01 PM |
"Black Screen" Running Sweet Home 3D on QEMU/KVM on AMD Hi I'm running Sweet Home 3D (6.6.2+dfsg-1) on a virtual machine (QEMU/KVM) on Ubuntu 22.04. The host box is also Ubuntu 22.04 (AMD Ryzen 3 2200G with Radeon Vega Graphics) When it launches it briefly shows the screens. But then everything turns black. When I click on an area it will briefly show it but then switch back to black a moment later. This issue may have already been addressed but I thought I'd ask. I know there were discussions about AMD graphics drivers but I have the latest as far as I know. Any thoughts would be appreciated. Thanks! |
| Posted by Keet at Oct 4, 2023, 8:23:49 AM |
Re: "Black Screen" Running Sweet Home 3D on QEMU/KVM on AMD 1. Remove your 6.6 Sweet Home 3D version. The version from the repository is way too old. Download and install the latest 7.2 version. 2. If you have not configured direct throughput of your graphics card to the virtual machine it's not AMD but a virtualized graphics card. 4. Use the SweetHome3D-Java3D_1_5_2 startup script instead of the default SweetHome3D script. (This alone will probably solve your problem with the 6.6 version too.) 3. Make sure your graphics driver is up-to-date if running from the host or with direct access to the graphics card enabled. 5. In my experience using Sweet Home 3D inside a virtual machine is slower than on the host. You'll experience this when projects get bigger. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by LearningSH3D at Oct 4, 2023, 2:43:03 PM |
Re: "Black Screen" Running Sweet Home 3D on QEMU/KVM on AMD Thanks Keet! I'll make these changes. Plus check/plan on VM migration if there's a performance issue. I appreciate it! |
Current timezone is GMT Oct 8, 2026, 4:45:36 AM |
