Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: View 3d model of the created house on mobile |
| Print at Sep 26, 2026, 9:32:30 PM |
| Posted by kawal at Oct 4, 2023, 11:09:43 AM |
View 3d model of the created house on mobile Hello Which is the best way to view our created house on browser (desktop/laptop) or on mobile phone? I am assuming I must select all and export the project into .obj file or is there any other efficient way? I am wondering which is the best way to view it on browser or phone? Thanks |
| Posted by Keet at Oct 4, 2023, 12:19:56 PM |
Re: View 3d model of the created house on mobile If it has to be from a browser read up on the Export to HTML5 plug-in. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by kawal at Oct 4, 2023, 3:26:44 PM |
Re: View 3d model of the created house on mobile That help.. Thanks Keet What about mobile phone? how to navigate in rooms and other places of the the obj file? |
| Posted by Keet at Oct 4, 2023, 4:47:13 PM |
Re: View 3d model of the created house on mobile If the mobile phone browser supports WebGL there should be no problem. The first post of the link I provided explains what the limitations are, mainly a max size for the project: And yes, I repeat, the result works on smartphones and tablets compatible with WebGL, including iOS and Android devices as well as zoom gestures available on touch screens. If you mainly target these platforms, don't be too greedy, because the compatibility with WebGL on those devices doesn't guaranty you can load and run a home file of any size on them (10 MB is probably a reasonable limit nowadays). ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Puybaret at Oct 4, 2023, 6:12:17 PM |
Re: View 3d model of the created house on mobile If you don't know where to host the files exported by the plug-in, you could also try Exported homes manager. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Keet at Oct 4, 2023, 6:33:32 PM |
Re: View 3d model of the created house on mobile @Emmanuel, is the Exported homes Manager also available for install on private servers? If it is, is there some kind of user management so I could give a select group access for viewing? ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by kawal at Oct 5, 2023, 10:19:14 AM |
Re: View 3d model of the created house on mobile I can see the top view on mobile and I can navigate too. I was wondering if virtual tour navigation is possible on mobile devices. Like the one we have in sh3d software, the virtual visitor |
| Posted by kawal at Oct 5, 2023, 11:46:36 AM |
Re: View 3d model of the created house on mobile I am so sorry, I did not see the virtual visit at the bottom left order. I checked it and I can navigate on mobile browser. Thanks |
| Posted by Keet at Oct 5, 2023, 12:27:20 PM |
Re: View 3d model of the created house on mobile If you open the viewHome.html file with a text editor you can change some settings in the viewHome(...) function call. For example changing the start level, set which levels are selectable, and some camera settings. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Puybaret at Oct 5, 2023, 2:36:46 PM |
Re: View 3d model of the created house on mobile Is the Exported homes Manager also available for install on private servers? No, because it strongly depends on how the database is organised on sweethome3d.com, with the forum being used as SSO (Single Sign-On). If it is, is there some kind of user management so I could give a select group access for viewing? It rather grants view access to all or keeps the home file private.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 26, 2026, 9:32:30 PM |
