Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Rugs and carpets |
| Print at Sep 24, 2026, 10:08:17 AM | |
| Posted by matts at Jan 8, 2010, 3:39:22 PM |
Rugs and carpets I am new to this product so maybe this is obvious to others. How can I put a rug or a carpet on the floor? |
| Posted by hansmex at Jan 8, 2010, 4:48:00 PM |
Re: Rugs and carpets Matts, Download and import a rug: http://sweethome3d.eu/importModels.jsp Scroll down to find the rugs. If you want another rug, search a nice picture, delete the "carpet.jpg" file and create another jpg-file WITH THE SAME NAME. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by matts at Jan 8, 2010, 6:33:12 PM |
Re: Rugs and carpets Thank you very much. |
| Posted by YvesNY at Sep 28, 2015, 2:09:40 PM |
Re: Rugs and carpets Hi! Where do you import the files? What folder should they go to ? |
| Posted by VenessaMartin at Feb 4, 2017, 9:20:37 AM |
Re: Rugs and carpets Thanks for the information! |
| Posted by Puybaret at Feb 4, 2017, 4:02:46 PM |
Re: Rugs and carpets This is a very old thread and there could be an easier way to do in recent versions: Add a Box found in Miscellaneous category, resize it to the dimension of a carpet. Then, in its modification dialog box, click on the Modify button beside Materials option, select top material and change its texture with the image of a carpet you'll import. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Jessica071 at Jan 22, 2026, 3:09:40 PM |
Re: Rugs and carpets Adding rugs definitely makes the 3D view feel more 'homey.' One thing I’ve started doing is picking out the actual rug I want first so the colors in the render are accurate. I’ve been using some of the transitional patterns from Dash & Albert Rugs lately—you can just save the top-down view of the rug and import it as a 'User defined' texture in Sweet Home 3D. It makes a huge difference in the final lighting of the room when the rug texture looks authentic. |
| Posted by MarioSambol at Jan 23, 2026, 12:15:38 AM |
Re: Rugs and carpets Yes, use primitive 3d object for this, or enithing else |
Current timezone is GMT Sep 24, 2026, 10:08:17 AM |
