Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Webcomponent support in SweetHome3D JS |
| Print at Oct 6, 2026, 2:20:30 PM |
| Posted by jogibear9988 at Oct 26, 2023, 5:40:40 PM |
Webcomponent support in SweetHome3D JS I'd like to use SweetHome3D in a webcomponent. But the viewHome function requires a element id. Would it be possible, if I use a HTMLElement as a parameter instead of a string, you use the compoent you get hand over, instead of search yourself for the component. So it could be use inside of a webcomponent? |
| Posted by jogibear9988 at Oct 26, 2023, 9:16:14 PM |
Re: Webcomponent support in SweetHome3D JS One of the changes needed would be this: https://github.com/node-projects/sweethome3d-...72b7d3ad5525bdad72e0af8d3 |
| Posted by jogibear9988 at Oct 26, 2023, 9:35:20 PM |
Re: Webcomponent support in SweetHome3D JS and this one https://github.com/node-projects/sweethome3d-...c05b6c30613b5c101e70a4e40 |
| Posted by jogibear9988 at Oct 26, 2023, 9:36:49 PM |
Re: Webcomponent support in SweetHome3D JS Can I create Pull reuests? Never used sourceforge in the last years? |
| Posted by jogibear9988 at Oct 26, 2023, 10:49:25 PM |
Re: Webcomponent support in SweetHome3D JS I now also remove the "define" calls from some additional libs. Cause I use "monaco" editor in my frontend, wich is using require/define and this does not work with the libs. In these the code is only for nodejs support, but I think it is not needed there. Best would be to switch to es6... see commit: https://github.com/node-projects/sweethome3d-...cbbfc5f6507a62f1a5cc97d57 |
| Posted by jogibear9988 at Oct 26, 2023, 10:51:29 PM |
Re: Webcomponent support in SweetHome3D JS One of the changes needed would be this: https://github.com/node-projects/sweethome3d-...72b7d3ad5525bdad72e0af8d3 was the wrong commit, this is the correct one: https://github.com/node-projects/sweethome3d-...63ae5f6c4f938b90985781e1d |
| Posted by jogibear9988 at Oct 26, 2023, 11:05:11 PM |
Re: Webcomponent support in SweetHome3D JS And another fix for activeElement inside shadowRoot: https://github.com/node-projects/sweethome3d-...e619a7388972e1c350031f992 |
| Posted by jogibear9988 at Oct 26, 2023, 11:19:38 PM |
Re: Webcomponent support in SweetHome3D JS here is a sample how it could be used: https://node-projects.github.io/web-component...projects-sweet-home-3d%3E |
| Posted by jogibear9988 at Oct 28, 2023, 9:55:04 AM |
Re: Webcomponent support in SweetHome3D JS @Puybaret what do you think about the changes? i would do them myself, if there is a way to create pull requests. |
| Posted by Kunda at Nov 1, 2023, 1:04:29 PM |
Re: Webcomponent support in SweetHome3D JS You can make patches and then submit them on the forum or directly to sourceforge |
Current timezone is GMT Oct 6, 2026, 2:20:30 PM |
