Print at Sep 24, 2026, 1:40:36 AM
Posted by jogibear9988 at Oct 26, 2023, 6:07:30 PM
License question
I'll try to create a webcomponent wrapper for the viewer, wich already works after a small fix: (I created anothe rpost about this)
https://github.com/node-projects/sweethome3d-...72b7d3ad5525bdad72e0af8d3
But now I have a question.
Am I allowed to do this? And can my wrapper have a MIT Licence or does the Wrapper also need to be GPL Licenced?
Posted by Puybaret at Oct 26, 2023, 8:15:56 PM
Re: License question
Any subversion of Sweet Home 3D JS must be released under GNU GPL.
Posted by jogibear9988 at Oct 26, 2023, 9:15:22 PM
Is it a subversion when I only use the library inside of a component?
Posted by Daniels118 at Oct 27, 2023, 6:21:58 AM
The point isn't if it is just a wrapper or a derived version. If you include it in your work, the final license must be GPL. You may license your own code under MIT, but if you distribute it along with a GPL software, the whole work must be GPL. In other words, a GPL sw may contains MIT sw, but not the opposite.
Posted by jogibear9988 at Oct 27, 2023, 8:36:50 AM
Switched to GPLv2
