Print at Oct 5, 2026, 8:53:21 AM
Posted by libertyline at Nov 1, 2023, 12:15:42 AM
smile   How to create radius measurements?
Hey everyone!
New user here. I am a general contractor building homes for disabled veterans.
One of the requirements to be shown in floor plans is the turn radius minimum requirements for a wheelchair (generally 3'-4').
They want this to be shown as a circular radius measurement, not simply a linear measurement between obstacles.
I will attach an image link as an example.
Is this feature available on Sweet Home 3D?
https://drive.google.com/file/d/1Lbq_CwWqxAbR...fFUYG/view?usp=drive_link
Posted by hansmex at Nov 1, 2023, 9:16:51 AM
Re: How to create radius measurements?
If >I< had to do this, I would use walls...
1 - draw a wall from A to B, than back to A
2 - Use Modify Walls - change Height and Thickness to 1 or 0.1, and Arc Extent to 180 - this gives a perfect circle that looks like a line
3 - Add Dimensions manually, or use Autodimensiong plugin (link).
Posted by Puybaret at Nov 1, 2023, 9:24:57 AM
You could also use this PWD symbol model designed for this purpose. It just different materials in case you want to show only the wheelchair symbol or the circle.
Posted by libertyline at Nov 1, 2023, 5:50:55 PM
perfect, THANK YOU!
Great community here, I appreciate the quick reply!
