Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Curtain rendering problem |
| Print at Oct 8, 2026, 6:55:25 PM | |
| Posted by Tutmozis at Nov 15, 2023, 9:18:53 PM |
Curtain rendering problem Hello. I have problem with default curtain rendering. At first image, you can see it from default 3D view, and the curtain looks great for me. But when I render, some strange problems occur. Curtain looks bad, using Yafa or SunFlow, both are terrible at best rendering, what’s wrong ? Picture |
| Posted by hansmex at Nov 16, 2023, 6:24:34 AM |
Re: Curtain rendering problem When following link to picture, I get message: Site does not exist H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Tutmozis at Nov 16, 2023, 7:41:52 AM |
Re: Curtain rendering problem Wondering how to edit my post :D Here the image: Picture But I figured out, I changed the transparency at mtl. |
| Posted by Puybaret at Nov 16, 2023, 10:21:18 AM |
Re: Curtain rendering problem Which version of Sweet Home 3D do you use? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Tutmozis at Nov 16, 2023, 4:04:24 PM |
Re: Curtain rendering problem Which version of Sweet Home 3D do you use? Hello. Version 7, the latest I guess. |
| Posted by Puybaret at Nov 16, 2023, 6:24:55 PM |
Re: Curtain rendering problem Some issues were fixed for transparency handling in version 7.2, so if you use version 7.0 or 7.1, you should install the last version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 8, 2026, 6:55:25 PM |
