Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Export plan image |
| Print at Oct 7, 2026, 3:13:09 PM | |
| Posted by jllh76 at Nov 19, 2023, 6:39:09 PM |
Export plan image Hello, There is a limitation of 10000 pixels to export the plan image. Is it possible to remove this limitation to export images with more details? Thanks in advance |
| Posted by Keet at Nov 19, 2023, 7:46:23 PM |
Re: Export plan image Did you use Plan>Export to SVG format? I haven't seen a limit there. I just exported a huge plan to SVG. Result: a 74MB SVG file with 30591x30590 pixels. (The plan I used is about 306x306 meters.) Inkscape had no problem opening it and that's where I got the pixel information from. Which version of Sweet Home 3D did you use and on what system? ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by jllh76 at Nov 19, 2023, 9:16:20 PM |
Re: Export plan image Hello Keet, I'm using the latest version 7.2 and the goal is to have a png or jpeg file output. My question was about Tool > Export plan image. I just tried it with Plan > Export svg option, in fact the quality is perfect. With a converter behind, I was able to obtain a jpeg. For a future version, it could be interesting to remove the limitation of Tool > Export plan image option to directly have a high resolution image file. Thanks |
| Posted by Keet at Nov 19, 2023, 9:35:25 PM |
Re: Export plan image My question was about Tool > Export plan image. Ah yes, that's a plugin I didn't install so I didn't think about it. But if the SVG option works for you then your problem is solved.---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Daniels118 at Nov 20, 2023, 2:25:07 AM |
Re: Export plan image I strongly recommend the installation of this plugin, which makes the exported svg smaller: https://sourceforge.net/p/sweethome3d/plug-ins/43/ |
| Posted by jllh76 at Nov 20, 2023, 1:24:25 PM |
Re: Export plan image I installed your plugin Daniels118, thank you for your help |
Current timezone is GMT Oct 7, 2026, 3:13:09 PM |
