Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to set up teh angle between two walls ? |
| Print at Oct 8, 2026, 6:54:30 PM | |
| Posted by miro_ilias at Nov 25, 2023, 6:34:32 PM |
How to set up teh angle between two walls ? Hello ! Please how do I set up the angle between two walls ? See the linked picture - I have to create walls based on the floor plan. https://drive.google.com/file/d/1ECSigHU3DnBn...vdRv9oCK/view?usp=sharing Thanks. |
| Posted by sjb007 at Nov 25, 2023, 7:09:41 PM |
Re: How to set up teh angle between two walls ? I take it the problem is the snapping to fixed angles? It is because you have magnetism set on. In the screenshot you can see an icon of a magnet. Click that to disable magnetism. You can then drag your endpoints to any angle. |
| Posted by miro_ilias at Nov 25, 2023, 7:53:47 PM |
Re: How to set up teh angle between two walls ? Thanks ! This helped, my problem is solved. |
Current timezone is GMT Oct 8, 2026, 6:54:30 PM |
