Print at Oct 3, 2026, 5:52:43 PM
Posted by rolffj at Nov 30, 2023, 7:06:23 PM
Years of Projects hang on MacBookProM1Max after Sonoma 14.1.1 update?
After years of successful use of paid version via Mac AppStore, program (regularly updated to 7.2.1) and all projects (now showing "Recover" added to names) now hang with spinning beach ball on MacBookProM1Max after upgrading to Sonoma 14.1.1 (not beta). Attempts to reopen via App Store prior purchase "Open" link produce same hanging results.
For troubleshooting, downloaded free Java 8 version 7.2 that does open (with limited libraries of course), yet crashes if try to open any recent projects. Can begin a new project only on free version.
How might I regain access to earlier projects and extensive libraries that I previously imported, please? Thank you for the assistance.
Posted by Puybaret at Nov 30, 2023, 7:52:24 PM
Re: Years of Projects hang on MacBookProM1Max after Sonoma 14.1.1 update?
How big are your SH3D file? Your projects might have become very large in which case you should try to increase the max memory used the program.
Posted by rolffj at Nov 30, 2023, 9:13:24 PM
Was able to expand memory to 6GB per instructions. However, program still hangs until force quit.
Recent project file size trying to open only 1.2MB (though 600kb version also won't open), while earlier ones were 13.8MB and as large as 36MB (with 3D view routinely separated onto a second or third monitor).
Additional sugestions, please? Thank you.
Posted by Puybaret at Nov 30, 2023, 9:26:03 PM
Your files are quite small, so the problem must come from something else.
Did you import some large 3D models?
Posted by rolffj at Nov 30, 2023, 9:40:58 PM
The Applications/SweetHome folder where all the models and multiple imported libraries of many doors, stairs, roofs, etc. appear to be is 334MB in size. The separate folder with all my projects is 490MB. The terrabyte hard drive has 189GB available besides extending onto multiple external drives as needed. Insights?
Posted by rolffj at Nov 30, 2023, 9:56:13 PM
I like the program and don't object to purchasing it again if I'm guided via links on how to delete everything except the projects and libraries, if possible. I feel like having the 7.2 Universal and iOS and 7.2.1 Mac App Store versions simultaneously on my computer from troubleshooting attempts may be making things worse? Is that likely? Thanks again.
Posted by Puybaret at Dec 1, 2023, 11:27:47 AM
Having both versions installed on the same computer is not a problem, except of course if you try to save a same file opened in both applications at the same time.
As explained here, imported 3D models and textures are not saved at the same place for both applications, and this is the only thing that may trouble users who are not aware of this.
Could you check the contents of Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/Library/Application Support/eTeks/Sweet Home 3D folder?
In the Finder, select Go > Go To... menu item, then enter ~/Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/Library/Application Support/eTeks/Sweet Home 3D (with the tilde) and press <enter>. If that folder contains a folder named "recovery", moving it elsewhere will let you restart the Mac App Store verison of Sweet Home 3D and open your SH3D files.
Posted by rolffj at Dec 1, 2023, 3:31:23 PM
That seemed to work to get the program open with full libraries, thank you.
Exception is only a few older project files open without force quit, yet I can recreate the few still needed later. The only one in Recovery folder still hangs but OK for now.
Also the "com.eteks.sweethome3d" portion was not in the path, instead going directly from /Containers to SweetHome3D/
Do I empty the moved Recovery folder and place it back where it was in case ever needed again, or just leave it where I moved it earlier in that path as I have done that worked?
Thank you very much for the patient and thorough assistance. You've created a wonderful program that is appreciated! Merci
Posted by Puybaret at Dec 1, 2023, 4:31:00 PM
You're welcome smile
Both paths work, Sweet Home 3D being a shortcut of com.eteks.sweethome3d.SweetHome3D.
Please, send me the file found in Recovery folder if you don't mind. It shouldn't hang program launch, and it will help me to understand why.
You can discard the Recovery folder if you want. It will be created again if needed.
Posted by rolffj at Dec 1, 2023, 6:55:08 PM
Attached to an email as requested. Thanks again.
Posted by rolffj at Dec 2, 2023, 3:03:58 AM
Sorry to be back here again so soon.
There is apparently something more seriously off as project I worked on today won't reload without Force Quit after restarting computer, and shows up in a newly created Recovery folder in same place. Tried moving that but then project partially opens with small B&W watches over each on screen library item with spinning ball Force Quit as only option. Open to suggestions at your convenience, please. Thank you.
Posted by Puybaret at Dec 14, 2023, 2:18:01 PM
Rolf, would you mind to update macOS to 14.2 released this week to check if Sweet Home 3D behaves better?
Posted by rolffj at Dec 14, 2023, 6:09:11 PM
Mac Sonoma 14.2 upgrade done for ver 7.2.1 from Mac App Store. While recent files open and changes can be made, still nothing will print. Even if modify Page Setup to exclude furniture list and 3D view, a one level floor plan also produces beachball Force Quit as only option. The same occurs whether 3D View in main window, separated on same monitor, or showing on a different monitor (preferred for easier viewing). Also same results after Save and Compress.
Appreciate the help as trying to design a home addition and I like your program. Thank you.
Posted by Puybaret at Dec 14, 2023, 6:27:17 PM
So there's some progress, which is already some good news.
About printing, note that you can copy/paste selected items in the furniture list in spreadsheet software, copy/paste selected items in the plan in imaging or word processing software and generate images of the 3D view with the photo creation tool.
At least, this will let you circumvent your printing issue.
Thanks for your feedback.
Posted by rolffj at Dec 14, 2023, 6:57:48 PM
Those workarounds will get me by for now. Thank you.
Happy Holidays!
