Print at Oct 3, 2026, 6:46:43 AM
Posted by paulo_05 at Jan 6, 2024, 7:03:51 PM
Is it possible to render multiple files for the SAME point of view?
Hello, I'd like to ask if it's possible to render multiple files for the same point of view during a period so I'll be able to see the sun incidence in the room.
So, for the same point of view I'd like to render images from different dates & times, it is possible to make a batch work for that?
Thanks....
Posted by Puybaret at Jan 7, 2024, 9:00:11 AM
Re: Is it possible to render multiple files for the SAME point of view?
Each point of view stores the date and time you selected in the photo creation tool. Therefore, you just have to store different points of view changing only the time for each for them, then choose the 3D view > Create photos at points of view menu item to compute all the pictures.
Similarly, you may create directly a video showing sun incidence using the video creation tool, as explained in this tip.
Posted by paulo_05 at Jan 9, 2024, 11:27:57 AM
Thank you!
