Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Hovering Ceiling |
| Print at Oct 10, 2026, 2:24:06 AM | |
| Posted by myers6mm at Jan 10, 2024, 1:17:59 AM |
Hovering Ceiling Hello! I'm working on my first project and I'm having an issue with the ceiling for the main floor. The garage and basement ceilings are just fine but the main floor is hovering about 8in above the walls. When I started the project I thought the house floor was 24in above the garage floor. After creating all the walls and most rooms on the main floor I started on the basement. After getting the walls and most of the rooms done there I realized the house floor was only 16in above the garage floor. I then adjusted the elevations of the basement and main floor down 8in to fix it. It's like something I can't see didn't move down and is holding the ceiling up. House File If someone could take a look and tell me what I need to do to fix it, that would be great! Thank you. |
| Posted by Puybaret at Jan 10, 2024, 1:58:14 PM |
Re: Hovering Ceiling There must be an issue in the way the height of some ceilings are computed but I didn't succeed to reproduce your problem on a simpler house. Meanwhile you could unckeck the Flat ceiling only option on the rooms which have this issue. This will adjust the corners of the ceiling to the closer wall height and fix your issue. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Jan 10, 2024, 2:21:42 PM |
Re: Hovering Ceiling I found your issue: it's coming from a wall placed at (1.441', -1.748') with a zero length. The height of this wall is 120in and this influences the height of the ceilings at the last level. Removing this wall will fix your issue. Use a rectangle selection to select it, then shift key to remove other items from the selection before deleting it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by myers6mm at Jan 10, 2024, 2:47:48 PM |
Re: Hovering Ceiling Thank you for the solution! Thank you for the program! Donation made! |
| Posted by Puybaret at Jan 10, 2024, 2:59:10 PM |
Re: Hovering Ceiling Thanks for the donation ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 10, 2026, 2:24:06 AM |
