Print at Oct 4, 2026, 10:38:06 AM View all posts in this thread on one page
Posted by LizardCobra at Jan 26, 2024, 1:14:13 AM
Zoom doesn't work with scroll wheel, pan only pans vertically
How can I zoom in the 2Dj view using the mouse scroll wheel? I can't find this in the help anywhere. I read a couple of places that holding Ctrl or Shift should work, but it doesn't. Scrolling with just the scroll wheel alone also does not zoom. The only way I can zoom in the 2D view is using the menu buttons, which is just so inefficient that it makes the software basically unusable.
The pan behavior is also pretty wonky. I can pan using the scroll wheel or holding Shift + scroll, but it moves in very large jumps. How can I pan smoothly (smaller increments)?
Posted by Puybaret at Jan 26, 2024, 4:10:13 PM
Re: Zoom doesn't work with scroll wheel, pan only pans vertically
You don’t have the choice between Ctrl and Shift to zoom. Only Ctrl + mouse wheel will work (or command key + mouse wheel under macOS) if you place the mouse pointer on the plan.
About spanning step, you should probably adjust your mouse wheel in system settings. There’s no other setting in Sweet Home 3D anyway.
Posted by LizardCobra at Jan 26, 2024, 4:25:15 PM
Sorry, I should have explained better. I didn't really expect there to be a choice between using the two different keys; I meant to say only that I tested using Shift just to see if maybe that would work.
When I place the mouse pointer on the plan, Ctrl + mouse scroll does not do anything for me. I'm on Windows.
Posted by LizardCobra at Jan 26, 2024, 10:26:37 PM
Is this a bug? Or is there something that would prevent zooming with the scroll wheel? It doesn't work in any situation.
Posted by LizardCobra at Jan 26, 2024, 10:41:15 PM
I tried to adjust the scroll wheel settings of my mouse. It was already very low, but I adjusted it down to the lowest value, but unfortunately that didn't make any difference with the minimum distance that it pans.
Posted by Daniels118 at Jan 28, 2024, 2:57:06 PM
Have you activated the plan view? Please read the warning at the end of the user interface chapter in the user guide:
http://www.sweethome3d.com/userGuide.jsp#userInterface
Also take a look at the pan 3d view plugin, despite its name it alliws to pan the pan view too using the middle mouse button, which I feel more comfortable than wheel/shift+wheel.
