Print at Oct 2, 2026, 7:57:37 AM
Posted by MartinH81 at Feb 17, 2024, 8:55:25 AM
Not perpendicular triangle
Hi
Does someone know how to create a non-perpendicular triangle in sweet home 3d? I got a triangle from a furniture lib, but it is perpendicular.
Bestregards
Martin
Posted by Keet at Feb 17, 2024, 9:10:27 AM
Re: Not perpendicular triangle
You can rotate the triangle along the X and Y axes. If you need to rotate both X and Y, first set the X, export/import, and then you can set the Y.
Of course you can also use the Generate 3D Shape tool under the Tools menu to generate any shape with 8 or less points. (That's the ShapeGenerator plugin if you haven't installed that yet.)
Posted by Puybaret at Feb 17, 2024, 9:18:28 AM
You can also create a triangle room at a higher level, export it at OBJ format and import it as a piece of furniture.
