Print at Oct 2, 2026, 6:09:18 AM
Posted by archibaldtuttle at Feb 17, 2024, 10:45:44 PM
set default wall thickness?
my walls are creating at 3 inches thick. i can double click each one and make it 4.5 (I'm assuming since it allows colors as if painted on the surface the the thickness normati vely be 4.5. I cannot find how to address the wall tool so it creates walls at 4.5 inches. Is there a way to set the default? thanks you , brian
Posted by Puybaret at Feb 18, 2024, 12:12:01 AM
Re: set default wall thickness?
Look in preferences panel
Posted by archibaldtuttle at Feb 18, 2024, 2:01:32 PM
@puybaret got it. thank you
